주요 콘텐츠로 건너뛰기
HP Pavilion dv6-6117dx WiFi Adapter Replacement
필요한 것
  1. HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: 1 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: 1 단계, 이미지 2개 중 2개
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 2 단계, 이미지 2개 중 2개
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 4 단계, 이미지 3개 중 3개
    • Using a spudger, remove the white and black antenna wires from the WiFi Adapter
    • When connecting these wires later, line up the connector and press straight down until you feel them snap in place.
  5. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 5 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screw driver, remove the two 4mm screws holding the WiFi adapter in place
    • After the screws are removed the WiFi Adapter will raise to a 45º angle.
  6. HP Pavilion dv6-6117dx WiFi Adapter Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx WiFi Adapter Replacement: 6 단계, 이미지 2개 중 2개
    • Always handle the WiFi Adapter by the edges to avoid damaging the part.
    • Pull the WiFi Adapter out of the slot at a 45º angle.
    • When inserting the new WiFi Adapter, you should insert it at this same angle.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Joshua Holme
회원 가입일: 03/19/18
765 평판
안내서 4개를 작성함
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 UMass Dartmouth, Team S6-G3, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G3
3 회원들
안내서 4개를 작성함
댓글 2개
Thanks i need to replace the wifi adapter in an old pc of mine,looks pretty simple.
pturner14 - 답글
I have hp dv6 notebook pc ww140AAR unable to load any OS. While installing the os a Blue Screen popup "ur pc runs into a problem need to shutdown" and then shutdown. And heating too much. Local engeneer said u have the replace the motherboard.what should I do now. Plz. Guide me.
Tanveer alam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 14
전체 시간: 2,499
