주요 콘텐츠로 건너뛰기
HP Pavilion dv6-6180us Speaker Replacement
필요한 것
  1. HP Pavilion dv6-6180us Speaker Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the hard drive wire to detach the hard drive.
  7. HP Pavilion dv6-6180us Speaker Replacement, Speaker: 7 단계, 이미지 1개 중 1개
    • Unscrew four 3.5 mm screws from the inside of the battery compartment with PH 1 screwdriver.
    • Unscrew nine 5 mm screws with PH 1 screwdriver.
    • Unscrew four 4 mm screws with PH 1 screwdriver.
  8. HP Pavilion dv6-6180us Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Flip right-side up and open the laptop.
    • Pry open the keyboard using plastic opening tool starting from the top.
    • Lift up keyboard gently,as a silver ribbon is still attaching it to the laptop
  9. HP Pavilion dv6-6180us Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Place keyboard upside down.
    • Lift up plastic cover over keyboard ribbon cable.
    • Pull ribbon cable up away from keyboard to completely remove.
  10. HP Pavilion dv6-6180us Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Remove seven 4mm pannel screws with PH 1 screwdriver.
  11. HP Pavilion dv6-6180us Speaker Replacement: 11 단계, 이미지 1개 중 1개
    • Put the computer on its side
    • Separate top panel from bottom frame.
  12. HP Pavilion dv6-6180us Speaker Replacement: 12 단계, 이미지 1개 중 1개
    • Pop open palm rest panel.
  13. HP Pavilion dv6-6180us Speaker Replacement: 13 단계, 이미지 1개 중 1개
    • Pull ribbon to detach from bottom panel.
  14. HP Pavilion dv6-6180us Speaker Replacement: 14 단계, 이미지 2개 중 1개 HP Pavilion dv6-6180us Speaker Replacement: 14 단계, 이미지 2개 중 2개
    • Lift up speaker.
  15. HP Pavilion dv6-6180us Speaker Replacement: 15 단계, 이미지 1개 중 1개
    • Lift up white panel covering speaker ribbon cable.
  16. HP Pavilion dv6-6180us Speaker Replacement: 16 단계, 이미지 1개 중 1개
    • Pull out the speaker ribbon.
  17. HP Pavilion dv6-6180us Speaker Replacement: 17 단계, 이미지 2개 중 1개 HP Pavilion dv6-6180us Speaker Replacement: 17 단계, 이미지 2개 중 2개
    • Unhook speaker cable from hooks.
  18. HP Pavilion dv6-6180us Speaker Replacement: 18 단계, 이미지 1개 중 1개
    • Pull out silver wire to reveal black speaker wire.
  19. HP Pavilion dv6-6180us Speaker Replacement: 19 단계, 이미지 1개 중 1개
    • Unplug the red, white, and black speaker wire connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
michelle pulido
회원 가입일: 09/15/16
859 평판
안내서 4개를 작성함
CSU Fullerton, Team 1-2, Bruce Fall 2016 CSU Fullerton, Team 1-2, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G2
4 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 23
전체 시간: 2,663
