주요 콘텐츠로 건너뛰기
HP Pavilion dv6-6c51ca Memory (RAM) Replacement
  1. HP Pavilion dv6-6c51ca Memory (RAM) Replacement, Remove the battery: 1 단계, 이미지 3개 중 1개 HP Pavilion dv6-6c51ca Memory (RAM) Replacement, Remove the battery: 1 단계, 이미지 3개 중 2개 HP Pavilion dv6-6c51ca Memory (RAM) Replacement, Remove the battery: 1 단계, 이미지 3개 중 3개
    • Make sure to turn off the computer and unplug the AC adapter from the computer. It is good practice to remove the battery and any other power source before working with any internal part in your computer.
    • REMOVING THE BATTERY: Flip the laptop over with the battery side facing up.
    • Slide the battery release latch to release the battery.
    • Pivot the front edge of the battery up and back.
    • Remove the battery.
    • REPLACING THE BATTERY: Align the tabs on the rear edge of the battery with the notches on the rear edge of the battery bay.
    • Pivot the front edge of the battery down into the battery bay until it is fully seated. (The battery release latch will automatically lock into place.)
    • Battery part number: 593554-001
  2. HP Pavilion dv6-6c51ca Memory (RAM) Replacement, Remove the service cover: 2 단계, 이미지 3개 중 1개 HP Pavilion dv6-6c51ca Memory (RAM) Replacement, Remove the service cover: 2 단계, 이미지 3개 중 2개 HP Pavilion dv6-6c51ca Memory (RAM) Replacement, Remove the service cover: 2 단계, 이미지 3개 중 3개
    • Note: As as safety feature, the service cover cannot be removed without removing the battery first.
    • Slide the service cover release latch to release the service cover.
    • Lift the rear edge of the service cover up and forward until it rests at an angle, being careful not to break the small plastic tabs that hold the cover in place. (A plastic spudger can be used to release the tabs)
    • Remove the service cover.
  3. HP Pavilion dv6-6c51ca Memory (RAM) Replacement, Remove the memory module: 3 단계, 이미지 3개 중 1개 HP Pavilion dv6-6c51ca Memory (RAM) Replacement, Remove the memory module: 3 단계, 이미지 3개 중 2개 HP Pavilion dv6-6c51ca Memory (RAM) Replacement, Remove the memory module: 3 단계, 이미지 3개 중 3개
    • Spread the retaining tabs on each side of the memory module slot to release the memory module. (The memory module tilts up.)
    • Remove the memory module by pulling it away from the slot at an angle.
결론
Some notes to consider:
  • Make sure to use compatible memory modules when replacing the old memory modules.
  • Make sure to line up the notches on the memory slots before inserting them. Do not force it in, as the memory module can only fit one way on the slot.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cokyaw
회원 가입일: 10/13/18
512 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 221
