주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion dv6000 Camera Replacement
필요한 것
  1. HP Pavilion dv6000 Camera Replacement, Camera: 1 단계, 이미지 2개 중 1개 HP Pavilion dv6000 Camera Replacement, Camera: 1 단계, 이미지 2개 중 2개
    • Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
    • If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 Camera Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion dv6000 Camera Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion dv6000 Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Press the tabs in on the sides of the screen and pop the plastic covering off.
    • The edges of the LCD screen are very sharp. Take care to not cut your fingers!
  3. HP Pavilion dv6000 Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the screen out of the casing at the top near the camera.
    • Take care to not snap the plastic casing! It is brittle and still attached to the bottom of the screen.
  4. HP Pavilion dv6000 Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Gently remove the main cable from the camera.
  5. HP Pavilion dv6000 Camera Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv6000 Camera Replacement: 5 단계, 이미지 2개 중 2개
    • There are three clasps holding the camera down. Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings).
    • The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
  6. HP Pavilion dv6000 Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the camera unit from the laptop and you are done!
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ben Hirsch
회원 가입일: 10/05/10
3,856 평판
안내서 10개를 작성함
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 회원
CPSU-REGAN-F10S21G33
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 42
전체 시간: 10,297
