주요 콘텐츠로 건너뛰기
HP Pavilion dv6000 Camera Replacement
필요한 것
  1. HP Pavilion dv6000 Camera Replacement, Camera: 1 단계, 이미지 1/2 HP Pavilion dv6000 Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
    • If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 Camera Replacement: 2 단계, 이미지 1/3 HP Pavilion dv6000 Camera Replacement: 2 단계, 이미지 2/3 HP Pavilion dv6000 Camera Replacement: 2 단계, 이미지 3/3
    • Press the tabs in on the sides of the screen and pop the plastic covering off.
    • The edges of the LCD screen are very sharp. Take care to not cut your fingers!
  3. HP Pavilion dv6000 Camera Replacement: 3 단계, 이미지 1/1
    • Lift the screen out of the casing at the top near the camera.
    • Take care to not snap the plastic casing! It is brittle and still attached to the bottom of the screen.
  4. HP Pavilion dv6000 Camera Replacement: 4 단계, 이미지 1/1
    • Gently remove the main cable from the camera.
  5. HP Pavilion dv6000 Camera Replacement: 5 단계, 이미지 1/2 HP Pavilion dv6000 Camera Replacement: 5 단계, 이미지 2/2
    • There are three clasps holding the camera down. Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings).
    • The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
  6. HP Pavilion dv6000 Camera Replacement: 6 단계, 이미지 1/1
    • Remove the camera unit from the laptop and you are done!
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ben Hirsch
회원 가입일: 10/05/10
3,826 평판
안내서 10개 작성하였습니다
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 회원
CPSU-REGAN-F10S21G33
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 9,929
