주요 콘텐츠로 건너뛰기
HP Pavilion dv6000 Hard Drive Replacement
필요한 것
  1. HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Remove the two screws from the hard drive shield and lift it off starting at the right side. The screws will remain in the shield.
  2. HP Pavilion dv6000 Hard Drive Replacement: 2 단계, 이미지 1/2 HP Pavilion dv6000 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Pull the plastic tab attached to the hard drive. The hard drive lifts right out. Pull gently so you don't damage the contacts.
  3. HP Pavilion dv6000 Hard Drive Replacement: 3 단계, 이미지 1/2 HP Pavilion dv6000 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Now you have your hard drive out!
  4. HP Pavilion dv6000 Hard Drive Replacement: 4 단계, 이미지 1/2 HP Pavilion dv6000 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Gently pull forward the HP adapter from the top of the hard drive.
    • Insert the adapter onto the new SATA hard drive, to be replaced in the laptop.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Ben Hirsch
회원 가입일: 10/05/10
3,841 평판
안내서 10개 작성하였습니다
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 회원
CPSU-REGAN-F10S21G33
4 회원들
안내서 12개 작성하였습니다
댓글 2개
thanks for your help
moyguens - 답글
I was scratching my head when I recvd the new hd w/out the adapter... LOL! thanks
gilaraujog - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 14
30일 전: 48
전체 시간: 41,384
