이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the two screws from the hard drive shield and lift it off starting at the right side. The screws will remain in the shield.
Pull the plastic tab attached to the hard drive. The hard drive lifts right out. Pull gently so you don't damage the contacts.
Gently pull forward the HP adapter from the top of the hard drive.
Insert the adapter onto the new SATA hard drive, to be replaced in the laptop.
다른 19명이 해당 안내서를 완성하였습니다.
댓글 2개
I was scratching my head when I recvd the new hd w/out the adapter... LOL! thanks
gilaraujog - 답글
