주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion dv6000 Keyboard Replacement
필요한 것
  1. HP Pavilion dv6000 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP Pavilion dv6000 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Remove the battery from the back of the computer.
    • Remove the two 7.2mm screws underneath holding the keyboard in.
    • Use a Phillips screwdriver to remove the three screws in the battery well.
  2. HP Pavilion dv6000 Keyboard Replacement, Loosen the keyboard: 2 단계, 이미지 3개 중 1개 HP Pavilion dv6000 Keyboard Replacement, Loosen the keyboard: 2 단계, 이미지 3개 중 2개 HP Pavilion dv6000 Keyboard Replacement, Loosen the keyboard: 2 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the two screws securing the RAM door.
    • Lift and remove the RAM door.
    • Use a Phillips screwdriver to remove the screw securing the keyboard to the laptop.
  3. HP Pavilion dv6000 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion dv6000 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion dv6000 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Flip the laptop back over (keyboard side up).
    • Pop the bezel off of the case by reaching underneath it.
    • Carefully remove the three ribbons underneath the bezel which attach it to the computer.
  4. HP Pavilion dv6000 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion dv6000 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Gently lift the keyboard out of the casing by holding the top edge (as shown). Be careful to keep the lower edge of the keyboard in place as you lift because there is a ribbon attached to the back (marked in red).
    • The keyboard is held in by six small tabs (2 on the top and 4 on the bottom). Lifting the bevel frees the top two. Free the bottom four tabs by sliding the keyboard forward towards the screen.
  5. HP Pavilion dv6000 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv6000 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the ribbon from the computer by pulling straight back (away from the track pad and towards the monitor).
  6. HP Pavilion dv6000 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • DONE!
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Ben Hirsch
회원 가입일: 10/05/10
3,856 평판
안내서 10개를 작성함
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 회원
CPSU-REGAN-F10S21G33
4 회원들
안내서 12개를 작성함
3가이드 댓글
Actually, there are three screws in the step 1.
The third one is hidden under the cover for the memory box!!!
Be careful, otherwise the dammage is granted.
harley029 - 답글 공유
Actually I was able to remove the keyboard fairly easily following the steps provided. However even after quite a few attempts at replacing it with either the new one I purchased or even the old one I am still unable to secure the data ribbon into the appropriate connector.therefore the keyboard is not functional… HELP!!! PLEASE??
James Osment - 답글 공유
You need probably put flat cable under the plastic connector and push small plastic in. First I put cable on top and it doesn’t work.
But the easier is to unscrew tree additional screws in battery compartment and not disconnect cables.
Pawel - 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 26
지난 30일: 86
전체 시간: 26,016
