주요 콘텐츠로 건너뛰기
HP Pavilion dv6000 LCD Screen Replacement
필요한 것
  1. HP Pavilion dv6000 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/2 HP Pavilion dv6000 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/2
    • Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 LCD Screen Replacement: 2 단계, 이미지 1/2 HP Pavilion dv6000 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
  3. HP Pavilion dv6000 LCD Screen Replacement: 3 단계, 이미지 1/2 HP Pavilion dv6000 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
  4. HP Pavilion dv6000 LCD Screen Replacement: 4 단계, 이미지 1/2 HP Pavilion dv6000 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Take out the two 3.58mm screws on the LCD at the top (one on each edge).
  5. HP Pavilion dv6000 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
  6. HP Pavilion dv6000 LCD Screen Replacement: 6 단계, 이미지 1/3 HP Pavilion dv6000 LCD Screen Replacement: 6 단계, 이미지 2/3 HP Pavilion dv6000 LCD Screen Replacement: 6 단계, 이미지 3/3
    • Let the screen gently rest on the keyboard.
    • Remove the tape from the ribbon.
    • Stop here and check the cable
결론
다른 15명이 해당 안내서를 완성하였습니다.
Ben Hirsch
회원 가입일: 10/05/10
3,826 평판
안내서 10개 작성하였습니다
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 회원
CPSU-REGAN-F10S21G33
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
after replacing my cracked screen the back light does not show again
firelionkofi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 39,281
