주요 콘텐츠로 건너뛰기
HP Pavilion dv6000 Speaker Bar Replacement
필요한 것
  1. HP Pavilion dv6000 Speaker Bar Replacement, Speaker Bar: 1 단계, 이미지 1/1
    • Make sure the laptop lid is closed, turn it over and remove the battery by moving the switch right to left.
    • there are three philips screws located on the surface where the writing is. remove those three screws.
  2. HP Pavilion dv6000 Speaker Bar Replacement: 2 단계, 이미지 1/1
    • turn the laptop right side up. Between the cover and case on the top right of the laptop and using a plastic sludger or a finger lift gently on the speaker cover as to disengage the clips.
    • Be sure not to pull hard or you may damage the ribbon cables.
    • From the side closest to the screen turn the cover towards yourself.
  3. HP Pavilion dv6000 Speaker Bar Replacement: 3 단계, 이미지 1/1
    • there is one connector from the speaker bar to a control board. Gently remove the cable.
    • There are two more screws attaching the speaker bar to the cover, remove these and take the speaker bar out.
  4. HP Pavilion dv6000 Speaker Bar Replacement: 4 단계, 이미지 1/1
    • you are now ready to replace or repair the speaker bar. I recomend purchasing a new one, they range anywhere from 5-15 dollars online.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Joba Fett
회원 가입일: 04/11/14
227 평판
안내서 1개 작성함
댓글 2개
how to fix speaker from board
kingsley Osunkwo - 답글
Grazie siete bravissimi . Ce ne fossero persone come voi che altruisticamente mettono a disposizione la loro esperienza di riparazioni per gli altri!
Fernando Mancini
fernando mancini - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 3,382
