주요 콘텐츠로 건너뛰기
HP Pavilion dv6000 Wireless Card Replacement
필요한 것
  1. HP Pavilion dv6000 Wireless Card Replacement, Wireless Card: 1 단계, 이미지 1/1
    • Lay the laptop on a flat surface, battery side up.
    • Remove the two screws securing the RAM shield to the lower case.
    • The screws will remain captive within the shield.
    • Lift and remove the RAM shield up from the lower case.
  2. HP Pavilion dv6000 Wireless Card Replacement: 2 단계, 이미지 1/2 HP Pavilion dv6000 Wireless Card Replacement: 2 단계, 이미지 2/2
    • Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card.
    • Be careful to pull on the contacts and not the wires. The crimps used to hold them to the wires are delicate.
  3. HP Pavilion dv6000 Wireless Card Replacement: 3 단계, 이미지 1/1
    • Remove the two 3.7 mm Phillips screws securing the wireless card to the motherboard.
    • Upon removing the Phillips screws that secures the wireless card to the motherboard, the wireless card board should pop up from its top side.
    • Grasp the wireless card and pull it straight out of its socket on the motherboard.
  4. HP Pavilion dv6000 Wireless Card Replacement: 4 단계, 이미지 1/1
    • Wireless card remains.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Ben Hirsch
회원 가입일: 10/05/10
3,826 평판
안내서 10개 작성하였습니다
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 회원
CPSU-REGAN-F10S21G33
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 26,601
