소개
In this guide, we will explain in a few short steps the process that will need to be taken in order to replace either of the RAM cards inserted in the laptop.
필요한 것
Remove fifteen 7.0mm PH0 screws.
Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
이 단계에 사용된 도구:Tweezers$4.99
Using your fingers or thin non metallic tweezers, pull the 2 silver levers on either side of the RAM card outward to until the ends pop up.
Slide the RAM cards out of their sockets.
다른 4명이 해당 안내서를 완성하였습니다.
