주요 콘텐츠로 건너뛰기
HP Pavilion dv6t-1200 Disk Tray Replacement
필요한 것
  1. HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: 1 단계, 이미지 1/2 HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: 1 단계, 이미지 2/2
    • Locate the small hole on the right side of the disk tray next to the button.
  2. HP Pavilion dv6t-1200 Disk Tray Replacement: 2 단계, 이미지 1/2 HP Pavilion dv6t-1200 Disk Tray Replacement: 2 단계, 이미지 2/2
    • Extend the paper clip into a straight line and insert it into the disk tray hole located next to the release button.
    • When the disk tray is removed, make sure to clean the general area with canned air.
  3. HP Pavilion dv6t-1200 Disk Tray Replacement: 3 단계, 이미지 1/1
    • Flip the laptop to the other side and remove the four screws on the bottom of the disk tray using a Phillips #0 screwdriver.
  4. HP Pavilion dv6t-1200 Disk Tray Replacement: 4 단계, 이미지 1/2 HP Pavilion dv6t-1200 Disk Tray Replacement: 4 단계, 이미지 2/2
    • Remove the metal plate and locate the bottom right tool for the disk tray.
  5. HP Pavilion dv6t-1200 Disk Tray Replacement: 5 단계, 이미지 1/2 HP Pavilion dv6t-1200 Disk Tray Replacement: 5 단계, 이미지 2/2
    • Replace the motor piece that is being held and reclose the device.
  6. HP Pavilion dv6t-1200 Disk Tray Replacement: 6 단계, 이미지 1/2 HP Pavilion dv6t-1200 Disk Tray Replacement: 6 단계, 이미지 2/2
    • After replacing the motor and the placing the metal tray apply a good amount of WD40.
    • Once all completed the disk tray should be working smoothly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Pelayo
회원 가입일: 10/05/21
210 평판
안내서 1개 작성함
CSU Los Angeles, Team 11-21, Grodsky Fall 2021 CSU Los Angeles, Team 11-21, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G21
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 7
전체 시간: 242
