주요 콘텐츠로 건너뛰기
HP Pavilion dv7-1285dx Hard Drive Replacement
필요한 것
  1. HP Pavilion dv7-1285dx Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Hard Drive Replacement, Back Plate: 2 단계, 이미지 1개 중 1개
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 2개
    • Rotate the device 180 degrees.
    • Locate the 2 black Phillips PM2.5×7.0 screws on the right side of the hard drive case and unscrew them.
  5. HP Pavilion dv7-1285dx Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion dv7-1285dx Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion dv7-1285dx Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Use the clear pull tab located on the left side of the hard drive case to unplug the hard drive by carefully pulling it to the left. Some force may be required.
    • After removing the hard drive, orient it such that the label face is up.
  6. HP Pavilion dv7-1285dx Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the 4 Phillips head screws located on the sides of the hard drive (two per side).
  7. HP Pavilion dv7-1285dx Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion dv7-1285dx Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion dv7-1285dx Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Hold the case as shown and use your thumbs to gently slide the hard drive out of its case.
    • Transfer the screws to the new hard drive case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jesse Quisido
회원 가입일: 04/14/14
489 평판
안내서 3개를 작성함
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 회원
CPSU-MANESS-S14S12G34
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 3,697
