주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion dv7-1285dx RAM Replacement
필요한 것
  1. HP Pavilion dv7-1285dx RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx RAM Replacement, Back Plate: 2 단계, 이미지 1개 중 1개
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx RAM Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx RAM Replacement, RAM: 4 단계, 이미지 1개 중 1개
    • Rotate the device 90 degrees to the left.
  5. HP Pavilion dv7-1285dx RAM Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion dv7-1285dx RAM Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion dv7-1285dx RAM Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the grey clips on the side of the RAM and pull the grey clips away from the RAM using the plastic opening tool.
  6. HP Pavilion dv7-1285dx RAM Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion dv7-1285dx RAM Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion dv7-1285dx RAM Replacement: 6 단계, 이미지 3개 중 3개
    • Unplug the RAM.
    • Repeat step 6 to remove the second piece of RAM.
  7. HP Pavilion dv7-1285dx RAM Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx RAM Replacement: 7 단계, 이미지 2개 중 2개
    • These steps are important in the replacement of the RAM, they will assist in ensuring the device is not damaged.
    • Align the notch in the new RAM with the peg on the plug
    • Ensure the RAM is fully inserted into the plug at a 45 degree angle such that the notch of the RAM lines up with the peg on the plug
  8. HP Pavilion dv7-1285dx RAM Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Push down gently on the RAM until the grey clips click.
    • Repeat steps 7 and 8 to replace the second piece of RAM.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jesse Quisido
회원 가입일: 04/14/14
489 평판
안내서 3개를 작성함
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 회원
CPSU-MANESS-S14S12G34
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 32
전체 시간: 1,337
