주요 콘텐츠로 건너뛰기
HP Pavilion dv7-1285dx Wifi Card Replacement
필요한 것
  1. HP Pavilion dv7-1285dx Wifi Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Wifi Card Replacement, Back Plate: 2 단계, 이미지 1개 중 1개
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Wifi Card Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Wifi Card Replacement: 3 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx Wifi Card Replacement, Wifi Card: 4 단계, 이미지 1개 중 1개
    • Locate the wifi card to the right of the RAM.
  5. HP Pavilion dv7-1285dx Wifi Card Replacement: 5 단계, 이미지 1개 중 1개
    • Unplug antenna cables 1 and 2 from their leads.
    • Antenna cable 3 is not used.
  6. HP Pavilion dv7-1285dx Wifi Card Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two Phillips head screws located on the battery compartment side of the wifi card.
  7. HP Pavilion dv7-1285dx Wifi Card Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift the wifi card up to a 45 degree angle from the side with screws.
  8. HP Pavilion dv7-1285dx Wifi Card Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion dv7-1285dx Wifi Card Replacement: 8 단계, 이미지 2개 중 2개
    • Unplug the wifi card.
  9. HP Pavilion dv7-1285dx Wifi Card Replacement: 9 단계, 이미지 1개 중 1개
    • These next steps are for installing your replacement wifi card. These steps are very important to ensure that you do not damage your device.
    • Fully insert the replacement wifi card at a 45 degree angle, ensuring that the notch on the card lines up with the peg on the plug.
  10. HP Pavilion dv7-1285dx Wifi Card Replacement: 10 단계, 이미지 1개 중 1개
    • Gently push the wifi card down until the screws can be replaced.
  11. HP Pavilion dv7-1285dx Wifi Card Replacement: 11 단계, 이미지 1개 중 1개
    • Connect the antenna cable 1 with lead 1 and connect antenna cable 2 with lead 2.
    • Wire 1 needs to be connected to lead 1 and wire 2 needs to be connected to lead 2.
    • Wire 3 and lead 3 are not used.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Anmol Mathur
회원 가입일: 04/14/14
291 평판
안내서 2개를 작성함
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 회원
CPSU-MANESS-S14S12G34
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 9
전체 시간: 2,226
