주요 콘텐츠로 건너뛰기
HP Pavilion dv7-1448dx Key Replacement
필요한 것
  1. HP Pavilion dv7-1448dx Key Replacement, Key: 1 단계, 이미지 1/1
    • Make sure the computer is unplugged and turned off.
    • Open the laptop so that the keyboard is fully exposed.
  2. HP Pavilion dv7-1448dx Key Replacement: 2 단계, 이미지 1/1
    • Place the plastic opening tool in the crevice near the key that needs to be removed.
    • This works best if the tool is placed at the top of the key.
  3. HP Pavilion dv7-1448dx Key Replacement: 3 단계, 이미지 1/1
    • Gently lever the tool downward until the key tilts upward.
    • At this point, move the tool around in order to completely pry the key off the keyboard. As the key is removed, small pops will be heard.
    • This step may take longer for larger keys.
    • When reinserting the key, gently press down until 2 clicks are heard (4 for larger keys).
  4. HP Pavilion dv7-1448dx Key Replacement: 4 단계, 이미지 1/1
    • Carefully remove the key from the base.
  5. HP Pavilion dv7-1448dx Key Replacement: 5 단계, 이미지 1/1
    • If the issue is a sticky key, make sure to clean the area once it is removed.
    • Use a cotton swab with alcohol to clean the underside of the key and the key slot.
결론
Kirsten Gilliland
회원 가입일: 01/30/17
741 평판
안내서 4개 작성하였습니다
Baylor, Team 3-5, Whitney Spring 2017 Baylor, Team 3-5, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G5
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 14
전체 시간: 395
