주요 콘텐츠로 건너뛰기
HP Pavilion dv7-1448dx RAM Replacement
필요한 것
  1. HP Pavilion dv7-1448dx RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx RAM Replacement: 2 단계, 이미지 1/2 HP Pavilion dv7-1448dx RAM Replacement: 2 단계, 이미지 2/2
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx RAM Replacement: 3 단계, 이미지 1/2 HP Pavilion dv7-1448dx RAM Replacement: 3 단계, 이미지 2/2
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
  4. HP Pavilion dv7-1448dx RAM Replacement, RAM: 4 단계, 이미지 1/3 HP Pavilion dv7-1448dx RAM Replacement, RAM: 4 단계, 이미지 2/3 HP Pavilion dv7-1448dx RAM Replacement, RAM: 4 단계, 이미지 3/3
    • Remove the six Phillips PM2.5X6.0 screws with a Phillips #00 screwdriver.
    • Pry the back casing up and away from the rest of the laptop with the plastic opening tool.
  5. HP Pavilion dv7-1448dx RAM Replacement: 5 단계, 이미지 1/3 HP Pavilion dv7-1448dx RAM Replacement: 5 단계, 이미지 2/3 HP Pavilion dv7-1448dx RAM Replacement: 5 단계, 이미지 3/3
    • Remove the green RAM by prying it upward and pulling it away from its slot.
결론
Kirsten Gilliland
회원 가입일: 01/30/17
741 평판
안내서 4개 작성하였습니다
Baylor, Team 3-5, Whitney Spring 2017 Baylor, Team 3-5, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G5
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 334
