주요 콘텐츠로 건너뛰기
HP Pavilion dv7-3065dx Disk Drive Replacement
필요한 것
  1. HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: 1 단계, 이미지 1/2 HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: 1 단계, 이미지 2/2
    • Remove the Battery as a safety precaution
    • There is a latch identified in the picture. By sliding this latch to the left, the battery is released from a lock position.
  2. HP Pavilion dv7-3065dx Disk Drive Replacement: 2 단계, 이미지 1/1
    • Use a Philips screwdriver to unscrew one screw holding the disk drive to the laptop.
    • In the photo there is a covering missing from another piece of the laptop but this will not impact the disk drive.
  3. HP Pavilion dv7-3065dx Disk Drive Replacement: 3 단계, 이미지 1/1
    • Slide (pull) the disk drive out from the laptop and place it off to the side.
    • The disk drive is the silver container as seen in the photo.
결론
Bailey York
회원 가입일: 02/07/17
101 평판
안내서 1개 작성함
Ohio State, Team 1-5, Wilder Spring 2017 Ohio State, Team 1-5, Wilder Spring 2017 회원
OSU-WILDER-S17S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 19
전체 시간: 737
