주요 콘텐츠로 건너뛰기
HP Pavilion dv7-3065dx Hard Drive Replacement
필요한 것
  1. HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Hard Drive Replacement: 3 단계, 이미지 1/2 HP Pavilion dv7-3065dx Hard Drive Replacement: 3 단계, 이미지 2/2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Hard Drive Replacement: 5 단계, 이미지 1/1
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Gabi Marino
회원 가입일: 02/07/17
157 평판
안내서 1개 작성함
Ohio State, Team 1-5, Wilder Spring 2017 Ohio State, Team 1-5, Wilder Spring 2017 회원
OSU-WILDER-S17S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 3,501
