주요 콘텐츠로 건너뛰기
HP Pavilion dv7-6178us Hard Drive Replacement
필요한 것
  1. HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Take note of where you place the screws because you will need them for later.
  3. HP Pavilion dv7-6178us Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion dv7-6178us Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop.
    • Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zach Lunghi
회원 가입일: 10/19/18
148 평판
안내서 1개를 작성함
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 UMass Dartmouth, Team S4-G8, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S4G8
4 회원들
안내서 6개를 작성함
댓글 한 개
This is a really GREAT thing that's being done!
It's high time that consumers fought back and stop letting the TECHNO-OVERLORDS, collectively STRIP us of the right to use the digital tools that we purchase from them.
Walter D Wormack - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 34
전체 시간: 2,044
