주요 콘텐츠로 건너뛰기
HP Pavilion dv7t-7000 Hard Drive Replacement
필요한 것
  1. HP Pavilion dv7t-7000 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Hard Drive Replacement, Back Panel: 4 단계, 이미지 1/1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Hard Drive Replacement: 5 단계, 이미지 1/2 HP Pavilion dv7t-7000 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/1
    • Remove the two Phillips #00 screws holding in the hard drive.
  7. HP Pavilion dv7t-7000 Hard Drive Replacement: 7 단계, 이미지 1/2 HP Pavilion dv7t-7000 Hard Drive Replacement: 7 단계, 이미지 2/2
    • Grab the black tab on the hard drive and pull left and then upwards to remove.
  8. HP Pavilion dv7t-7000 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Remove the four Phillips #00 screws holding the hard drive to its case.
  9. HP Pavilion dv7t-7000 Hard Drive Replacement: 9 단계, 이미지 1/2 HP Pavilion dv7t-7000 Hard Drive Replacement: 9 단계, 이미지 2/2
    • Slide the casing off of the hard drive.
  10. HP Pavilion dv7t-7000 Hard Drive Replacement: 10 단계, 이미지 1/1
    • Unplug the hard drive from the device.
결론
Gavin Loera
회원 가입일: 02/21/18
424 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 11
전체 시간: 388
