주요 콘텐츠로 건너뛰기
HP Pavilion dv7t-7000 Palm Rest Replacement
필요한 것
  1. HP Pavilion dv7t-7000 Palm Rest Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Palm Rest Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Palm Rest Replacement: 3 단계, 이미지 1개 중 1개
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Palm Rest Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Palm Rest Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Palm Rest Replacement: 5 단계, 이미지 2개 중 2개
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Palm Rest Replacement, RAM: 6 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Palm Rest Replacement, RAM: 6 단계, 이미지 2개 중 2개
    • Push the retraining springs away from the RAM at the same time to unlock the RAM.
  7. HP Pavilion dv7t-7000 Palm Rest Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Palm Rest Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the RAM out.
    • Follow the same procedure for the additional RAM.
  8. HP Pavilion dv7t-7000 Palm Rest Replacement, Wi-Fi Card: 8 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Palm Rest Replacement, Wi-Fi Card: 8 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pop off the antenna connectors.
  9. HP Pavilion dv7t-7000 Palm Rest Replacement: 9 단계, 이미지 3개 중 1개 HP Pavilion dv7t-7000 Palm Rest Replacement: 9 단계, 이미지 3개 중 2개 HP Pavilion dv7t-7000 Palm Rest Replacement: 9 단계, 이미지 3개 중 3개
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
  10. HP Pavilion dv7t-7000 Palm Rest Replacement, Keyboard: 10 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Palm Rest Replacement, Keyboard: 10 단계, 이미지 2개 중 2개
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  11. HP Pavilion dv7t-7000 Palm Rest Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion dv7t-7000 Palm Rest Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion dv7t-7000 Palm Rest Replacement: 11 단계, 이미지 3개 중 3개
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  12. HP Pavilion dv7t-7000 Palm Rest Replacement: 12 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  13. HP Pavilion dv7t-7000 Palm Rest Replacement, Palm Rest: 13 단계, 이미지 3개 중 1개 HP Pavilion dv7t-7000 Palm Rest Replacement, Palm Rest: 13 단계, 이미지 3개 중 2개 HP Pavilion dv7t-7000 Palm Rest Replacement, Palm Rest: 13 단계, 이미지 3개 중 3개
    • Flip the keyboard back over.
    • Remove the single Phillips #00 screw holding in the CD drive.
    • Pull out the CD drive.
  14. HP Pavilion dv7t-7000 Palm Rest Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the seventeen Phillips #00 screws securing the back panel to the laptop.
  15. HP Pavilion dv7t-7000 Palm Rest Replacement: 15 단계, 이미지 2개 중 1개 HP Pavilion dv7t-7000 Palm Rest Replacement: 15 단계, 이미지 2개 중 2개
  16. HP Pavilion dv7t-7000 Palm Rest Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the panel by lifting it up.
결론
작성자
1다른 기여자 명과 함께
Afnan
회원 가입일: 02/21/18
289 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 274
