주요 콘텐츠로 건너뛰기
HP Pavilion dv7t-7000 Wi-Fi Card Replacement
필요한 것
  1. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: 3 단계, 이미지 1/1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Back Panel: 4 단계, 이미지 1/1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: 5 단계, 이미지 1/2 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Wi-Fi Card: 6 단계, 이미지 1/2 HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Wi-Fi Card: 6 단계, 이미지 2/2
    • Use the flat end of a spudger to pop off the antenna connectors.
  7. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: 7 단계, 이미지 1/3 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: 7 단계, 이미지 2/3 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: 7 단계, 이미지 3/3
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
결론
Eric Easley
회원 가입일: 02/10/18
251 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 193
