주요 콘텐츠로 건너뛰기
HP Pavilion dv9000 Hard Drive Replacement
필요한 것
  1. HP Pavilion dv9000 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: 2 단계, 이미지 2개 중 1개 HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: 2 단계, 이미지 2개 중 2개
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1개 중 1개
    • There are two hard drive bays.
    • Hard drive bay 1 is in the lower right corner.
    • Hard drive bay 2 is in the lower left corner.
  4. HP Pavilion dv9000 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion dv9000 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • To remove hard drive 1 from bay 1
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws that hold the bay 1 cover in place.
    • The screws should remain in the cover.
  5. HP Pavilion dv9000 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv9000 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • After removing the two cover screws, lift and slide the cover out of position to access the hard drive.
    • Grab the clear plastic pull tab on top of the hard drive to lift the hard drive from the laptop.
  6. HP Pavilion dv9000 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion dv9000 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion dv9000 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • To remove hard drive 2 from bay 2.
    • Most laptops don't have a second hard drive. If yours does not, then proceed to the next step.
    • Using a Phillips #1 screwdriver remove the two 5 mm screws that hold the bay 2 cover in place.
    • Grab the clear plastic pull tab on top of the hard drive, and lift the hard drive from the laptop.
  7. HP Pavilion dv9000 Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion dv9000 Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion dv9000 Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • After the hard drive has been removed from the laptop, it must then be removed from its bracket.
    • Start by gently pulling the HP hard drive adapter from the end of the hard drive.
    • Using a Phillips #1 screwdriver, remove the four 3 mm bracketing screws on both sides of the hard drive bracket (2 per side) .
    • Lift the hard drive from its metal bracket.
    • Be careful not to touch the green underside as this may damage the hard drive.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Robby Cabri
회원 가입일: 01/23/14
178 평판
안내서 1개를 작성함
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 회원
CPSU-MANESS-W14S10G32
4 회원들
안내서 6개를 작성함
댓글 4개
Hello. In step 7 of the above, what is the name/part number/ size etc of the adapter/connector please ? I need one urgently.
Thanks.
freeflyshannon - 답글
yes that would be very helpfull because the new SSdrive I have will not fit even though is is the same size. I think I need some sort of an adaptor as you say.
Stephen Cox - 답글
For modern SATA SSDs, the typical form factor is 7.5mm. The standard for laptop HDDs is 9.5mm. You will need to buy a plastic spacer in order to properly mount the drive inside your computer.
Michael - 답글
thanks for the help
Stephen Cox - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 13
전체 시간: 9,121
