주요 콘텐츠로 건너뛰기
HP Pavilion dv9000 Keyboard Replacement
필요한 것
  1. HP Pavilion dv9000 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Keyboard Replacement, Battery Removal: 2 단계, 이미지 1/2 HP Pavilion dv9000 Keyboard Replacement, Battery Removal: 2 단계, 이미지 2/2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 HP Pavilion dv9000 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Remove the six 5 mm screws in the battery compartment using Phillips #1 screwdriver.
    • Remove the 7mm keyboard screw located towards the center of the laptop with a Phillips #1 screwdriver.
  4. HP Pavilion dv9000 Keyboard Replacement: 4 단계, 이미지 1/1
    • Flip the laptop over and open the lid.
    • Lift out the plastic panel containing the power button and flip it over.
    • Be careful, the panel is still attached by a small ribbon cable.
  5. HP Pavilion dv9000 Keyboard Replacement: 5 단계, 이미지 1/3 HP Pavilion dv9000 Keyboard Replacement: 5 단계, 이미지 2/3 HP Pavilion dv9000 Keyboard Replacement: 5 단계, 이미지 3/3
    • Locate the ribbon cable attached to the underside of the plastic panel.
    • Using a spudger, unplug the ribbon cable by pushing the brown tab away from circuit board and sliding the ribbon out with your hand.
    • Set the plastic panel aside.
  6. HP Pavilion dv9000 Keyboard Replacement: 6 단계, 이미지 1/3 HP Pavilion dv9000 Keyboard Replacement: 6 단계, 이미지 2/3 HP Pavilion dv9000 Keyboard Replacement: 6 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the three 5mm screws holding the keyboard in place.
    • Carefully lift the keyboard up (no more than a few cm) and slide it forward, towards the laptops monitor to reveal another larger ribbon cable.
    • Be extremely careful as the keyboard is still attached to the computer by the larger ribbon cable.
  7. HP Pavilion dv9000 Keyboard Replacement: 7 단계, 이미지 1/3 HP Pavilion dv9000 Keyboard Replacement: 7 단계, 이미지 2/3 HP Pavilion dv9000 Keyboard Replacement: 7 단계, 이미지 3/3
    • Use a spudger to push the black tab forward and slide it away from the white connector.
    • Gently pull the ribbon cable from the connector housing.
    • Remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erik Hoffnagle
회원 가입일: 04/11/13
750 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 회원
CPSU-MANESS-W14S10G32
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Please I have a problem with my hp laptop the keyboard and there is noise on it, repair it automatic. thanks you
Clement Glah - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 18
전체 시간: 3,169
