주요 콘텐츠로 건너뛰기
HP Pavilion dv9000 Wireless Card Replacement
필요한 것
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: 2 단계, 이미지 2개 중 1개 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: 2 단계, 이미지 2개 중 2개
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3개 중 1개 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3개 중 2개 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3개 중 3개
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion dv9000 Wireless Card Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion dv9000 Wireless Card Replacement: 4 단계, 이미지 3개 중 3개
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv9000 Wireless Card Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Erik Hoffnagle
회원 가입일: 04/11/13
768 평판
안내서 3개를 작성함
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 회원
CPSU-MANESS-W14S10G32
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 4,019
