주요 콘텐츠로 건너뛰기
HP Pavilion dv9000 Wireless Card Replacement
필요한 것
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: 2 단계, 이미지 1/2 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: 2 단계, 이미지 2/2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 1/3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 2/3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3/3
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: 4 단계, 이미지 1/3 HP Pavilion dv9000 Wireless Card Replacement: 4 단계, 이미지 2/3 HP Pavilion dv9000 Wireless Card Replacement: 4 단계, 이미지 3/3
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: 5 단계, 이미지 1/2 HP Pavilion dv9000 Wireless Card Replacement: 5 단계, 이미지 2/2
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Erik Hoffnagle
회원 가입일: 04/11/13
768 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 회원
CPSU-MANESS-W14S10G32
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 3,965
