주요 콘텐츠로 건너뛰기
HP Pavilion g4-1117dx Screen Replacement
필요한 것
  1. HP Pavilion g4-1117dx Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Screen Replacement, Screen: 3 단계, 이미지 1/3 HP Pavilion g4-1117dx Screen Replacement, Screen: 3 단계, 이미지 2/3 HP Pavilion g4-1117dx Screen Replacement, Screen: 3 단계, 이미지 3/3
    • Remove two triangular shaped screw covers in the bottom corners of the monitor near the hinges.
    • Unscrew the two 4.0 mm JIS #0 screws holding the hinge covers.
  3. HP Pavilion g4-1117dx Screen Replacement: 4 단계, 이미지 1/1
    • Pry off the monitor border cover.
  4. HP Pavilion g4-1117dx Screen Replacement: 5 단계, 이미지 1/2 HP Pavilion g4-1117dx Screen Replacement: 5 단계, 이미지 2/2
    • Remove four 4.0mm JIS #0 screws located at each corner of the monitor.
  5. HP Pavilion g4-1117dx Screen Replacement: 6 단계, 이미지 1/3 HP Pavilion g4-1117dx Screen Replacement: 6 단계, 이미지 2/3 HP Pavilion g4-1117dx Screen Replacement: 6 단계, 이미지 3/3
    • Remove the two silver hinge covers.
  6. HP Pavilion g4-1117dx Screen Replacement: 7 단계, 이미지 1/2 HP Pavilion g4-1117dx Screen Replacement: 7 단계, 이미지 2/2
    • Unplug at golden connector.
  7. HP Pavilion g4-1117dx Screen Replacement: 8 단계, 이미지 1/3 HP Pavilion g4-1117dx Screen Replacement: 8 단계, 이미지 2/3 HP Pavilion g4-1117dx Screen Replacement: 8 단계, 이미지 3/3
    • Remove four 3.0mm JIS #0 screws, two on each side of the screen.
  8. HP Pavilion g4-1117dx Screen Replacement: 9 단계, 이미지 1/1
    • Carefully remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Robert Hamilton
회원 가입일: 03/01/18
1,165 평판
안내서 10개 작성하였습니다
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 UMass Dartmouth, Team S2-G7, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G7
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
nice very informative
S i n o for pc - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 819
