소개
Although it does not have many prerequisites, the screen is without a doubt the most difficult part of the laptop to remove. There are several hidden screws and wire that need to be carefully removed.
필요한 것
Remove two triangular shaped screw covers in the bottom corners of the monitor near the hinges.
Unscrew the two 4.0 mm JIS #0 screws holding the hinge covers.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
