소개
This is a guide to locate and remove the laptop's hard drive.
필요한 것
Use the PH 00 screwdriver to unscrew the 2.5 mm screw to the right of the hard drive.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
I used my (brand new!) Pro Tech toolkit to work through these instructions. Everything was pretty much as advertised except that my Pavilion g series is apparently older than the displayed model. Specifically, there was no screw to the right of the drive, and the drive is completely encased in a rubber harness that is used to friction seat the drive, and the area where the pull tab would be is covered by a plastic shield that appears to be made of same electrostatic material as antistatic bags. Solution was simply to used standard spudger to lift rear of drive against friction from rubber harness, and then simply unplug the drive. Basically, this was a good doc; it got me going in the right direction.
