주요 콘텐츠로 건너뛰기
HP Pavilion g6-1b79dx Wireless Card Replacement
필요한 것
  1. HP Pavilion g6-1b79dx Wireless Card Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Wireless Card Replacement: 2 단계, 이미지 1/2 HP Pavilion g6-1b79dx Wireless Card Replacement: 2 단계, 이미지 2/2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Wireless Card Replacement: 3 단계, 이미지 1/2 HP Pavilion g6-1b79dx Wireless Card Replacement: 3 단계, 이미지 2/2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Wireless Card Replacement, Bottom Panel: 4 단계, 이미지 1/1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Wireless Card Replacement: 5 단계, 이미지 1/1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Wireless Card Replacement: 6 단계, 이미지 1/3 HP Pavilion g6-1b79dx Wireless Card Replacement: 6 단계, 이미지 2/3 HP Pavilion g6-1b79dx Wireless Card Replacement: 6 단계, 이미지 3/3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx Wireless Card Replacement, Wireless Card: 7 단계, 이미지 1/3 HP Pavilion g6-1b79dx Wireless Card Replacement, Wireless Card: 7 단계, 이미지 2/3 HP Pavilion g6-1b79dx Wireless Card Replacement, Wireless Card: 7 단계, 이미지 3/3
    • Unlatch the two antenna cable connectors from the wireless card.
  8. HP Pavilion g6-1b79dx Wireless Card Replacement: 8 단계, 이미지 1/1
    • Remove the two 2.5 mm screws in the wireless card with a PH00 screwdriver.
    • You may have to gently bend the cables away from the wireless card to remove the screws
  9. HP Pavilion g6-1b79dx Wireless Card Replacement: 9 단계, 이미지 1/3 HP Pavilion g6-1b79dx Wireless Card Replacement: 9 단계, 이미지 2/3 HP Pavilion g6-1b79dx Wireless Card Replacement: 9 단계, 이미지 3/3
    • Gently disconnect the wireless card from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Rachel Gallegos
회원 가입일: 09/22/15
873 평판
안내서 5개 작성하였습니다
Baylor, Team 10-12, Williams Fall 2015 Baylor, Team 10-12, Williams Fall 2015 회원
BU-WILLIAMS-F15S10G12
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 1,398
