주요 콘텐츠로 건너뛰기
HP Pavilion g6-2228tx Optical Drive Replacement
필요한 것
  1. HP Pavilion g6-2228tx Optical Drive Replacement, Battery: 1 단계, 이미지 1/2 HP Pavilion g6-2228tx Optical Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Push the battery latch to the left to release the battery.
    • Remove the battery from the device.
  2. HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: 2 단계, 이미지 1/2 HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: 2 단계, 이미지 2/2
    • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
  3. HP Pavilion g6-2228tx Optical Drive Replacement: 3 단계, 이미지 1/3 HP Pavilion g6-2228tx Optical Drive Replacement: 3 단계, 이미지 2/3 HP Pavilion g6-2228tx Optical Drive Replacement: 3 단계, 이미지 3/3
    • Place your hand on the cover and slide the cover down.
    • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
  4. HP Pavilion g6-2228tx Optical Drive Replacement: 4 단계, 이미지 1/2 HP Pavilion g6-2228tx Optical Drive Replacement: 4 단계, 이미지 2/2
    • Place one finger on the right side of the hard drive.
    • Push the hard drive to the left and lift the hard drive up to remove it from the device.
  5. HP Pavilion g6-2228tx Optical Drive Replacement: 5 단계, 이미지 1/2 HP Pavilion g6-2228tx Optical Drive Replacement: 5 단계, 이미지 2/2
    • Disconnect the connecting part by pulling the part to the right.
    • Remove the hard drive from the device.
  6. HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: 6 단계, 이미지 1/2 HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: 6 단계, 이미지 2/2
    • Remove the 2.5mm screw with a Phillips #0 screw drive.
  7. HP Pavilion g6-2228tx Optical Drive Replacement: 7 단계, 이미지 1/3 HP Pavilion g6-2228tx Optical Drive Replacement: 7 단계, 이미지 2/3 HP Pavilion g6-2228tx Optical Drive Replacement: 7 단계, 이미지 3/3
    • Put one finger into the release hole and push to the left until part of the optical drive comes out from the left of the laptop.
  8. HP Pavilion g6-2228tx Optical Drive Replacement: 8 단계, 이미지 1/3 HP Pavilion g6-2228tx Optical Drive Replacement: 8 단계, 이미지 2/3 HP Pavilion g6-2228tx Optical Drive Replacement: 8 단계, 이미지 3/3
    • Grab the optical drive and pull to the left to remove it from the device.
결론
Hai Lin
회원 가입일: 10/19/18
446 평판
안내서 4개 작성하였습니다
UC Davis, Team S4-G6, Lore Fall 2018 UC Davis, Team S4-G6, Lore Fall 2018 회원
UCD-LORE-F18S4G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 20
전체 시간: 945
