주요 콘텐츠로 건너뛰기
HP Pavilion g7-1150us Hard Drive Replacement
필요한 것
  1. HP Pavilion g7-1150us Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP Pavilion g7-1150us Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Hard Drive Replacement, Surface Panel: 3 단계, 이미지 1/1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Hard Drive Replacement: 4 단계, 이미지 1/2 HP Pavilion g7-1150us Hard Drive Replacement: 4 단계, 이미지 2/2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Hard Drive Replacement: 5 단계, 이미지 1/1
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/1
    • Grab the hard drive gently on either side. The left side is where the hard drive is connected to the laptop.
    • The hard drive was missing from our device.
  7. HP Pavilion g7-1150us Hard Drive Replacement: 7 단계, 이미지 1/1
    • Gently pull the hard drive to the right away from the connector. When fully disconnected you have safely removed the hard drive!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Gabriel Lurz
회원 가입일: 03/20/19
127 평판
안내서 1개 작성함
UMass Dartmouth, Team S6-G3, Peak Spring 2019 UMass Dartmouth, Team S6-G3, Peak Spring 2019 회원
UMASSD-PEAK-S19S6G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 814
