주요 콘텐츠로 건너뛰기
HP Pavilion g7-1365dx Optical Drive Replacement
필요한 것
  1. HP Pavilion g7-1365dx Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Optical Drive Replacement: 2 단계, 이미지 1/1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Optical Drive Replacement, Service Door: 3 단계, 이미지 1/2 HP Pavilion g7-1365dx Optical Drive Replacement, Service Door: 3 단계, 이미지 2/2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: 4 단계, 이미지 1/3 HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: 4 단계, 이미지 2/3 HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: 4 단계, 이미지 3/3
    • Using the Phillips size 00 screwdriver, unscrew the 4.7 mm screw that holds the optical drive.
    • Use the opening tool to slide the drive out the side of the laptop to remove it.
결론
Colin Klaes
회원 가입일: 03/21/19
259 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 UMass Dartmouth, Team S1-G1, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 164
