소개
This guide will give step by step instructions on how to remove the service door from an HP Pavilion g7-1365dx. Use this as a prerequisite guide for more involved guides.
필요한 것
Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
Push the switch above the battery towards the center of the laptop .
Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
Use the opening tool around the edges of the service door to loosen it and remove it.
