소개
This guide will show you how to replace the HP Pavilion g7-1368 hard drive. This process should take approximately 10 minutes using only a Phillips #1 screwdriver. Make sure to shut down the device before proceeding with the replacement.
필요한 것
Turn the device over so that the lower case is facing up.
Slide the battery release latch. The battery will pop up.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
