소개
This guide will show you how to switch out the battery for the HP Pavilion g7-1368x. Before beginning, make sure to completely power down the device. This process will take less than 5 minutes with a new battery. No tools are required for this replacement.
필요한 것
Turn the device over so that the lower case is facing up.
Slide the battery release latch. The battery will pop up.
다른 한 분이 해당 안내서를 완성하였습니다.
