주요 콘텐츠로 건너뛰기
HP Pavilion g7-1368dx Keyboard Replacement
필요한 것
  1. HP Pavilion g7-1368dx Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx Keyboard Replacement: 2 단계, 이미지 1/1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: 3 단계, 이미지 1/3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: 3 단계, 이미지 2/3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: 3 단계, 이미지 3/3
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
    • Slide the service panel down and pull it up to remove.
  4. HP Pavilion g7-1368dx Keyboard Replacement: 4 단계, 이미지 1/1
    • Remove the one 7 mm Phillips #1 screw securing the keyboard to the device.
  5. HP Pavilion g7-1368dx Keyboard Replacement: 5 단계, 이미지 1/1
    • Flip over the device and open the screen.
  6. HP Pavilion g7-1368dx Keyboard Replacement: 6 단계, 이미지 1/2 HP Pavilion g7-1368dx Keyboard Replacement: 6 단계, 이미지 2/2
    • Flip the keyboard over and locate the black ribbon cable that attaches the keyboard to the device.
    • Using a plastic opening tool, flip up the white tab on the zero insertion force connector.
    • Disconnect the ribbon cable by sliding it out of the ZIF connector.
    • Remove the keyboard.
결론
Kianna Young
회원 가입일: 01/16/19
109 평판
안내서 1개 작성함
University of Alabama, Team S2-G2, Bedsole Spring 2019 University of Alabama, Team S2-G2, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S2G2
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 285
