소개
In this guide, you will learn how to replace the keyboard of your HP Pavilion g7-1368dx. this process takes roughly 25 minutes. The tools that you will need to preform this replacement are a Philips #1 Screwdriver, and the plastic iFixit opening tool.
필요한 것
Turn the device over so that the lower case is facing up.
Slide the battery release latch. The battery will pop up.
Loosen the two Phillips #1 screws that connect the service panel to the device.
Slide the service panel down and pull it up to remove.
거의 끝나갑니다!
결론
