소개
There are a few reasons to replace the hard drive mounting bracket. Your hard drive mounting brakcet is faulty, or you want to replace your hard drive with a new hard drive. Whatever the reason, this guide will show you how to replace the hard drive mounting bracket. You can decide what hard drive you want to replace your in your device so long as the hard drive is a 9.5 mm (0.37 in) × 6.35 cm (2.50 in) SATA Hard Drive.
필요한 것
Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
Locate the hard drive cable connector pull tab.
Pinch the pull tab pulling upwards from the motherboard to disconnect the hard drive cable.
