주요 콘텐츠로 건너뛰기
HP Pavilion g7-2275dx Keyboard Replacement
필요한 것
  1. HP Pavilion g7-2275dx Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion g7-2275dx Keyboard Replacement: 2 단계, 이미지 1/1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. HP Pavilion g7-2275dx Keyboard Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: 3 단계, 이미지 1/1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. HP Pavilion g7-2275dx Keyboard Replacement: 4 단계, 이미지 1/2 HP Pavilion g7-2275dx Keyboard Replacement: 4 단계, 이미지 2/2
    • Slide the back panel down and pull it up.
  5. HP Pavilion g7-2275dx Keyboard Replacement, Keyboard: 5 단계, 이미지 1/1
    • Unscrew the 7 mm Phillips #1 screw next to the keyboard icon.
  6. HP Pavilion g7-2275dx Keyboard Replacement: 6 단계, 이미지 1/1
    • Flip the laptop over and open the screen.
  7. HP Pavilion g7-2275dx Keyboard Replacement: 7 단계, 이미지 1/2 HP Pavilion g7-2275dx Keyboard Replacement: 7 단계, 이미지 2/2
    • A ribbon cable is attached to the back of the keyboard. Avoid lifting or moving the keyboard more than a couple inches before you disconnect the ribbon cable or you may damage it.
    • Carefully pry up one of the top corners of the keyboard with a prying tool. Slide the tool along the top of the keyboard to release it from the housing. Pull the top of the keyboard towards you an inch or two.
    • The keyboard may make some cracking noises as you pry it from the casing. This is expected.
    • Pull the keyboard up and away from you, as it is held in by clips in the front. It is not yet disconnected.
  8. HP Pavilion g7-2275dx Keyboard Replacement: 8 단계, 이미지 1/1
    • Gently turn keyboard over, towards you, to reveal the silver cable ribbon.
  9. HP Pavilion g7-2275dx Keyboard Replacement: 9 단계, 이미지 1/3 HP Pavilion g7-2275dx Keyboard Replacement: 9 단계, 이미지 2/3 HP Pavilion g7-2275dx Keyboard Replacement: 9 단계, 이미지 3/3
    • Using a prying tool, flip the black clip up and to the right. Pull the silver cable out and to the left, the keyboard is now detached from the laptop.
결론
다른 8명이 해당 안내서를 완성하였습니다.
John Sutton
회원 가입일: 04/24/14
1,566 평판
안내서 8개 작성하였습니다
Cal Poly, Team 11-51, Amido Spring 2014 Cal Poly, Team 11-51, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G51
4 회원들
안내서 21개 작성하였습니다
댓글 3개
Good guide. It helped me going quicker at getting to the keyboard. Thank you!
antoniotavares - 답글
The keyboard for this computer is HP part number 640208-001 and it is not available anymore in HP. It is available in Amazon, however.
antoniotavares - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 11,025
