주요 콘텐츠로 건너뛰기
HP Pavilion g7-2275dx Wireless Card Replacement
필요한 것
  1. HP Pavilion g7-2275dx Wireless Card Replacement, Battery: 1 단계, 이미지 1/1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion g7-2275dx Wireless Card Replacement: 2 단계, 이미지 1/1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. HP Pavilion g7-2275dx Wireless Card Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: 3 단계, 이미지 1/1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. HP Pavilion g7-2275dx Wireless Card Replacement: 4 단계, 이미지 1/2 HP Pavilion g7-2275dx Wireless Card Replacement: 4 단계, 이미지 2/2
    • Slide the back panel down and pull it up.
  5. HP Pavilion g7-2275dx Wireless Card Replacement, Wireless Card: 5 단계, 이미지 1/1
    • Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
  6. HP Pavilion g7-2275dx Wireless Card Replacement: 6 단계, 이미지 1/2 HP Pavilion g7-2275dx Wireless Card Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to lift the wireless card out of its slot.
  7. HP Pavilion g7-2275dx Wireless Card Replacement: 7 단계, 이미지 1/2 HP Pavilion g7-2275dx Wireless Card Replacement: 7 단계, 이미지 2/2
    • Pull the black and white wires up and off of the wireless card.
    • Remove the wireless card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
John Sutton
회원 가입일: 04/24/14
1,566 평판
안내서 8개 작성하였습니다
Cal Poly, Team 11-51, Amido Spring 2014 Cal Poly, Team 11-51, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G51
4 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 2,218
