주요 콘텐츠로 건너뛰기
HP Pavilion p6 Wireless Card Replacement
필요한 것
  1. HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: 1 단계, 이미지 3개 중 1개 HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: 1 단계, 이미지 3개 중 2개 HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: 1 단계, 이미지 3개 중 3개
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
  2. HP Pavilion p6 Wireless Card Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion p6 Wireless Card Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion p6 Wireless Card Replacement: 2 단계, 이미지 3개 중 3개
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
  3. HP Pavilion p6 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3개 중 1개 HP Pavilion p6 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3개 중 2개 HP Pavilion p6 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3개 중 3개
    • First locate the wireless card, it should look like this.
    • Next using a spudger or equivalent carefully pry the antenna cable off the wireless card, it should now look like the second picture.
    • A single screw then needs to be removed in order to free the card.
  4. HP Pavilion p6 Wireless Card Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion p6 Wireless Card Replacement: 4 단계, 이미지 2개 중 2개
    • The card can then just be easily removed by pulling it out and up.
    • The wireless card should then be kept in a safe place and care taken not to lose the small screw that goes with it.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Oli
회원 가입일: 01/03/14
1,442 평판
안내서 4개를 작성함
댓글 2개
Thx this helped a lot with my pc
Nathan Moore - 답글
Also will the card still work without the antenna cable?
Nathan Moore - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 29
전체 시간: 2,970
