주요 콘텐츠로 건너뛰기
HP Pavilion x2 10-n113dx Mainboard Replacement
필요한 것
  1. HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx  Mainboard Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx  Mainboard Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx  Mainboard Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx  Mainboard Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx  Mainboard Replacement: 3 단계, 이미지 3개 중 3개
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx  Mainboard Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx  Mainboard Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx  Mainboard Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx  Mainboard Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx  Mainboard Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx  Mainboard Replacement: 5 단계, 이미지 3개 중 3개
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: 6 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: 6 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: 6 단계, 이미지 3개 중 3개
    • To unscrew the mainboard use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws
  7. HP Pavilion x2 10-n113dx  Mainboard Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx  Mainboard Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx  Mainboard Replacement: 7 단계, 이미지 3개 중 3개
    • Remove mainboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
David Zambrano
회원 가입일: 09/28/17
837 평판
안내서 5개를 작성함
USF Tampa, Team S13-G4, Boczar Fall 2017 USF Tampa, Team S13-G4, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G4
4 회원들
안내서 5개를 작성함
5가이드 댓글
Is this about the WiFi card? Because I cant see the SSD in any of your pictures.
Julian Lemmerich - 답글
So, where is the SSD? You’ve taken apart the whole logic board, but not evidence of any SSD module from your photos….
Matteo Repossi - 답글
It is not SSD drive, it is a motherboard
Da K - 답글
has anyone figured out where is the SSD (eMMC) by the way ?
Karantez Jegou - 답글
Do you happen to know how to reset the BIOS on this board if it does not boot?
Lewis Fields - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 33
전체 시간: 8,118
