주요 콘텐츠로 건너뛰기
HP Pavilion x2 10-n113dx Battery Replacement
필요한 것
  1. HP Pavilion x2 10-n113dx Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Battery Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Battery Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Battery Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Battery Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Battery Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Battery Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
David Zambrano
회원 가입일: 09/28/17
837 평판
안내서 5개를 작성함
USF Tampa, Team S13-G4, Boczar Fall 2017 USF Tampa, Team S13-G4, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 24
전체 시간: 5,776
