주요 콘텐츠로 건너뛰기
HP Pavilion x2 10-n113dx Camera Replacement
필요한 것
  1. HP Pavilion x2 10-n113dx Camera Replacement, Camera: 1 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Camera Replacement, Camera: 1 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Camera Replacement, Camera: 1 단계, 이미지 3개 중 3개
    • Separate the screen from the keyboard.
    • The keyboard and screen are held together via magnets.
    • Open the device and pull the screen parallel to its face.
  2. HP Pavilion x2 10-n113dx Camera Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Camera Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Separate the screen from body of the computer with a blue spudger.
    • Using a plastic spudger, gently begin separating the face from the body.
    • Separate each side gently.
  3. HP Pavilion x2 10-n113dx Camera Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Once each edge has been separated, gently lift the face (screen) from the back.
    • Be sure to not do so quickly or you risk tearing the keyboard ribbon cable.
    • Rotate the device 180 degrees for the following steps.
  4. HP Pavilion x2 10-n113dx Camera Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Follow the attached ribbon cable to the circuit board of the device.
    • On the side of the ribbon cable, use a small plastic spudger to pop open this plastic lock and gently pull in the direction of the cable to remove.
    • Gently lift up on the battery connector just below the earlier removed ribbon cable to remove.
  5. HP Pavilion x2 10-n113dx Camera Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew and remove each of the four indicated screws using the Phillips #0 screwdriver.
    • Begin with the bottom left 4.5mm diameter screw.
    • Continue to the remaining three 2.0 mm diameter screws.
    • Once all four screws have been removed lift the battery from the device using the indicated pull tab along the top edge.
  6. HP Pavilion x2 10-n113dx Camera Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Camera Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Using a small blue plastic spudger pop off the two speaker wires from the circuit board.
    • Once removed from the board carefully move the wires from the raised clips on the metal plating.
  7. HP Pavilion x2 10-n113dx Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove the 4.5mm screw from the camera circuit board.
    • Using a plastic spudger flip up the two rubber covers to the right and left of the 4.5mm screw.
  8. HP Pavilion x2 10-n113dx Camera Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Camera Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully remove the ribbon cable from the camera circuit board with tweezers.
    • Carefully remove the wire mesh tape from the metal plating using tweezers.
  9. HP Pavilion x2 10-n113dx Camera Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Using a plastic spudger remove the camera circuit board from the device.
결론
작성자
4다른 기여자 명과 함께
Cayla Skaggs
회원 가입일: 04/01/19
337 평판
안내서 2개를 작성함
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019 회원
IUPUI-HARLEY-S19S1G4
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 632
