소개
Use this guide to replace the hinge connector of your device.
필요한 것
Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
Using the Phillips #0 screwdriver, carefully remove the 21 screws that hold the screen to the display panel. 3.32 mm head, 3.99 mm length (RED) , 2.82 head 3.5 mm length (YELLOW), and 4.15 mm head, 2.35 mm length (BLUE).
3.32 mm head, 3.99 mm length.
2.82 head 3.5 mm length.
4.15 mm head, 2.35 mm length.
Use the Phillips #0 screwdriver to unscrew 2 screws 2.82 mm head 3.5 mm length from the hinge connector
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
THANK YOU SO MUTCH !!! My keyboard was broken but this is just that the cable wasn’t connected ! but i have only make step 1,2,3 and 4
