주요 콘텐츠로 건너뛰기
HP Pavilion x2 10-n113dx Hinge Replacement
필요한 것
  1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: 1 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: 1 단계, 이미지 2/2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Hinge Replacement: 2 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Hinge Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the grey rubber bar using plastic spudger or tweezers, exposing the four screw heads.
    • The rubber bar is attached with an adhesive. A heat pad may be required to melt the adhesive and allow for easier removal.
  3. HP Pavilion x2 10-n113dx Hinge Replacement: 3 단계, 이미지 1/1
    • Unscrew the four screws using the Phillips #0 screwdriver.
    • All four of these screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Hinge Replacement: 4 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Hinge Replacement: 4 단계, 이미지 2/2
    • Remove the circular rubber tabs exposing the screw heads below.
    • A heat pad may be required to melt the tab adhesive and allow for easier removal.
    • Unscrew the two screws using the Phillips #0 screwdriver.
    • These two screws are 5.3 mm in diameter and 4.3 mm in height.
  5. HP Pavilion x2 10-n113dx Hinge Replacement: 5 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Hinge Replacement: 5 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Hinge Replacement: 5 단계, 이미지 3/3
    • Once all screws have been removed, gently pry open the back casing using a metal spudger.
    • Be sure to use the spudger at the marked locations to avoid damage to the casing.
  6. HP Pavilion x2 10-n113dx Hinge Replacement: 6 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Hinge Replacement: 6 단계, 이미지 2/2
    • Completely remove the back casing.
  7. HP Pavilion x2 10-n113dx Hinge Replacement: 7 단계, 이미지 1/1
    • Unscrew the four screws located at the marked locations using the Phillips #0 screwdriver.
    • All fours of these screws have a 7.0 mm diameter an a 2.5 mm height.
  8. HP Pavilion x2 10-n113dx Hinge Replacement: 8 단계, 이미지 1/1
    • Remove adhesive that secures the ribbon cable using tweezers.
  9. HP Pavilion x2 10-n113dx Hinge Replacement: 9 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Hinge Replacement: 9 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Hinge Replacement: 9 단계, 이미지 3/3
    • Using a plastic spudger, flip open the switch for the connection port, allowing the ribbon cable to be removed.
  10. HP Pavilion x2 10-n113dx Hinge Replacement: 10 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Hinge Replacement: 10 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Hinge Replacement: 10 단계, 이미지 3/3
    • Gently lift the hinge from the attachment points as shown in the picture.
    • Tweezers can be also be used to ensure the ribbon cable does not get damaged in the process.
    • The hinge can now be completely separated.
결론
Ajay Panuganti
회원 가입일: 04/01/19
181 평판
안내서 1개 작성함
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019 회원
IUPUI-HARLEY-S19S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 1,134
