주요 콘텐츠로 건너뛰기
HP Pavilion x2 10-n113dx Hinge Replacement
필요한 것
  1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: 1 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: 1 단계, 이미지 2개 중 2개
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Hinge Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Hinge Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the grey rubber bar using plastic spudger or tweezers, exposing the four screw heads.
    • The rubber bar is attached with an adhesive. A heat pad may be required to melt the adhesive and allow for easier removal.
  3. HP Pavilion x2 10-n113dx Hinge Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the four screws using the Phillips #0 screwdriver.
    • All four of these screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Hinge Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Hinge Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the circular rubber tabs exposing the screw heads below.
    • A heat pad may be required to melt the tab adhesive and allow for easier removal.
    • Unscrew the two screws using the Phillips #0 screwdriver.
    • These two screws are 5.3 mm in diameter and 4.3 mm in height.
  5. HP Pavilion x2 10-n113dx Hinge Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Hinge Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Hinge Replacement: 5 단계, 이미지 3개 중 3개
    • Once all screws have been removed, gently pry open the back casing using a metal spudger.
    • Be sure to use the spudger at the marked locations to avoid damage to the casing.
  6. HP Pavilion x2 10-n113dx Hinge Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Hinge Replacement: 6 단계, 이미지 2개 중 2개
    • Completely remove the back casing.
  7. HP Pavilion x2 10-n113dx Hinge Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the four screws located at the marked locations using the Phillips #0 screwdriver.
    • All fours of these screws have a 7.0 mm diameter an a 2.5 mm height.
  8. HP Pavilion x2 10-n113dx Hinge Replacement: 8 단계, 이미지 1개 중 1개
    • Remove adhesive that secures the ribbon cable using tweezers.
  9. HP Pavilion x2 10-n113dx Hinge Replacement: 9 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Hinge Replacement: 9 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Hinge Replacement: 9 단계, 이미지 3개 중 3개
    • Using a plastic spudger, flip open the switch for the connection port, allowing the ribbon cable to be removed.
  10. HP Pavilion x2 10-n113dx Hinge Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Hinge Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Hinge Replacement: 10 단계, 이미지 3개 중 3개
    • Gently lift the hinge from the attachment points as shown in the picture.
    • Tweezers can be also be used to ensure the ribbon cable does not get damaged in the process.
    • The hinge can now be completely separated.
결론
작성자
3다른 기여자 명과 함께
Ajay Panuganti
회원 가입일: 04/01/19
181 평판
안내서 1개를 작성함
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019 회원
IUPUI-HARLEY-S19S1G4
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 14
전체 시간: 1,404
